[GRASS-dev] ps.map fprintf -> G_
Martin Landa
landa.martin at gmail.com
Thu Jan 4 05:42:35 EST 2007
Hi Jachym,
2007/1/3, Jachym Cepicky <jachym.cepicky at centrum.cz>:
> Hi,
> nice job, thanks for the patch, but when I'm thinking about it, ...
> this patch makes ps.map set it's verbosity not by the --quiet
> or --verbose flags, but also according to the input configuration file.
Right, this patch allows to set verbosity level by the --q/v flag or
by verbose mapping instruction.
> imho, the simplest solution should be, remove the VERBOSE keyword from
> ps.map. It would not harm to anythink. I doubt, some people are parsing
Not sure, it would break backward compatibility. OK, maybe the verbose
instruction should be removed later, now just printing appropriate
warning about it. There is also question about priority: the --q/v
flag should overwrite the mapping instruction or not?
> output from ps.map in their scripts.
> If so, G_set_verbose function is the best solution.
> What do others think?
> Jachym
Thanks for the feedback Jachym.
> On Tue, Dec 26, 2006 at 11:16:44AM +0100, Martin Landa wrote:
> > Hi all,
> > trying to change fprintf to G_message/warning/fatal_error in ps.map
> > module I found one complication. There is a special mapping
> > instruction --- VERBOSE. I think this instruction should overwrite
> > GRASS_VERBOSE environment variable(??). There is also need to have a
> > special function G_set_verbose() which allows to set a given verbosity
> > level after first calling of G_verbose() fn. Please look at the patch
> > (especially at verbose.c.diff). Thanks a lot.
> > Best regards, Martin
> > Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
> Jachym Cepicky
> e-mail: jachym.cepicky at centrum.cz
> URL: http://les-ejk.cz
> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
> OFFICE:
> Department of Geoinformation Technologies
> Zemedelska 3
> 613 00, Brno
> Czech Republick
> e-mail: xcepicky at node.mendelu.cz
> URL: http://mapserver.mendelu.cz
> Tel.: +420 545 134 514
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.3 (GNU/Linux)
> iD8DBQFFm97SyKt0uAjU4I8RAh4lAKCMce8cDJEO5Yf8Wra2msvgzAAfDwCfRraX
> tGACE41v2F2Yv2UKt6AXuEI=
> =2I9W
> -----END PGP SIGNATURE-----
