[GRASS-dev] ps.map fprintf -> G_
Martin Landa
landa.martin at gmail.com
Sun Jan 7 02:07:30 EST 2007
I have prepared a new version of the patch where verbose mapping
instruction is removed. It will cause "ERROR: verbose : illegal
request" when the verbose mapping instruction is used.
Not sure if we can just remove this instruction...
Regards, Martin
2007/1/4, Martin Landa <landa.martin at gmail.com>:
> Hi Jachym,
> 2007/1/3, Jachym Cepicky <jachym.cepicky at centrum.cz>:
> > Hi,
> > nice job, thanks for the patch, but when I'm thinking about it, ...
> > this patch makes ps.map set it's verbosity not by the --quiet
> > or --verbose flags, but also according to the input configuration file.
> Right, this patch allows to set verbosity level by the --q/v flag or
> by verbose mapping instruction.
> > imho, the simplest solution should be, remove the VERBOSE keyword from
> > ps.map. It would not harm to anythink. I doubt, some people are parsing
> Not sure, it would break backward compatibility. OK, maybe the verbose
> instruction should be removed later, now just printing appropriate
> warning about it. There is also question about priority: the --q/v
> flag should overwrite the mapping instruction or not?
> > output from ps.map in their scripts.
> > If so, G_set_verbose function is the best solution.
> > What do others think?
> > Jachym
> Thanks for the feedback Jachym.
> > On Tue, Dec 26, 2006 at 11:16:44AM +0100, Martin Landa wrote:
> > > Hi all,
> > > trying to change fprintf to G_message/warning/fatal_error in ps.map
> > > module I found one complication. There is a special mapping
> > > instruction --- VERBOSE. I think this instruction should overwrite
> > > GRASS_VERBOSE environment variable(??). There is also need to have a
> > > special function G_set_verbose() which allows to set a given verbosity
> > > level after first calling of G_verbose() fn. Please look at the patch
> > > (especially at verbose.c.diff). Thanks a lot.
> > > Best regards, Martin
> > > Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
> > > _______________________________________________
> > > grass-dev mailing list
> > > grass-dev at grass.itc.it
> > > http://grass.itc.it/mailman/listinfo/grass-dev
> > Jachym Cepicky
> > e-mail: jachym.cepicky at centrum.cz
> > URL: http://les-ejk.cz
> > GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
> > OFFICE:
> > Department of Geoinformation Technologies
> > Zemedelska 3
> > 613 00, Brno
> > Czech Republick
> > e-mail: xcepicky at node.mendelu.cz
> > URL: http://mapserver.mendelu.cz
> > Tel.: +420 545 134 514
> > -----BEGIN PGP SIGNATURE-----
> > Version: GnuPG v1.4.3 (GNU/Linux)
> > iD8DBQFFm97SyKt0uAjU4I8RAh4lAKCMce8cDJEO5Yf8Wra2msvgzAAfDwCfRraX
> > tGACE41v2F2Yv2UKt6AXuEI=
> > =2I9W
> > -----END PGP SIGNATURE-----
