[GRASS-dev] ps.map fprintf -> G_
Jachym Cepicky jachym.cepicky at centrum.cz
Sun Jan 7 03:18:13 EST 2007
hi,
On Sun, Jan 07, 2007 at 08:07:30AM +0100, Martin Landa wrote:
> Hi,
> I have prepared a new version of the patch where verbose mapping
> instruction is removed. It will cause "ERROR: verbose : illegal
> request" when the verbose mapping instruction is used.
On this place, I would vote for just a warning, so
+      /* Please, remove before GRASS 7 released */
  if (KEY("verbose"))
-      if (sscanf(data, "%d", &verbose) != 1) verbose = 2;
+      G_warning(_("verbose instruction was removed. Please use --verbose instead"));
      continue;
Otherwise, tha patch looks good to me
Thank you
Jachym
> Not sure if we can just remove this instruction...
> Regards, Martin
> 2007/1/4, Martin Landa <landa.martin at gmail.com>:
> >Hi Jachym,
> >2007/1/3, Jachym Cepicky <jachym.cepicky at centrum.cz>:
> >> Hi,
> >> nice job, thanks for the patch, but when I'm thinking about it, ...
> >>  this patch makes ps.map set it's verbosity not by the --quiet
> >> or --verbose flags, but also according to the input configuration file.
> >Right, this patch allows to set verbosity level by the --q/v flag or
> >by verbose mapping instruction.
> >> imho, the simplest solution should be, remove the VERBOSE keyword from
> >> ps.map. It would not harm to anythink. I doubt, some people are parsing
> >Not sure, it would break backward compatibility. OK, maybe the verbose
> >instruction should be removed later, now just printing appropriate
> >warning about it. There is also question about priority: the --q/v
> >flag should overwrite the mapping instruction or not?
> >> output from ps.map in their scripts.
> >> If so, G_set_verbose function is the best solution.
> >> What do others think?
> >> Jachym
> >Thanks for the feedback Jachym.
> >> On Tue, Dec 26, 2006 at 11:16:44AM +0100, Martin Landa wrote:
> >> > Hi all,
> >> > trying to change fprintf to G_message/warning/fatal_error in ps.map
> >> > module I found one complication. There is a special mapping
> >> > instruction --- VERBOSE. I think this instruction should overwrite
> >> > GRASS_VERBOSE environment variable(??). There is also need to have a
> >> > special function G_set_verbose() which allows to set a given verbosity
> >> > level after first calling of G_verbose() fn. Please look at the patch
> >> > (especially at verbose.c.diff). Thanks a lot.
> >> > Best regards, Martin
> >> > Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa
> >> > _______________________________________________
> >> > grass-dev mailing list
> >> > grass-dev at grass.itc.it
> >> > http://grass.itc.it/mailman/listinfo/grass-dev
> >> Jachym Cepicky
> >> e-mail: jachym.cepicky at centrum.cz
> >> URL: http://les-ejk.cz
> >> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
> >> OFFICE:
> >> Department of Geoinformation Technologies
> >> Zemedelska 3
> >> 613 00, Brno
> >> Czech Republick
> >> e-mail: xcepicky at node.mendelu.cz
> >> URL:    http://mapserver.mendelu.cz
> >> Tel.:   +420 545 134 514
> >> -----BEGIN PGP SIGNATURE-----
> >> Version: GnuPG v1.4.3 (GNU/Linux)
> >> iD8DBQFFm97SyKt0uAjU4I8RAh4lAKCMce8cDJEO5Yf8Wra2msvgzAAfDwCfRraX
> >> tGACE41v2F2Yv2UKt6AXuEI=
> >> =2I9W
> >> -----END PGP SIGNATURE-----
> >Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070107/fe8d0026/attachment.bin
