[GRASS-dev] G_program_name to every message / r.li
Helena Mitasova
hmitaso at unity.ncsu.edu
Sun Jan 7 17:23:43 EST 2007
On Jan 7, 2007, at 4:17 PM, Brad Douglas wrote:
> On Sun, 2007-01-07 at 19:00 +0100, Jachym Cepicky wrote:
>> Hallo,
>> I think it would be nice, if G_message, G_warning and G_fatal_error
>> would print module name at the beginning of the message.
>> If the modules are used in scripts, it is sometimes difficult to
>> identify, which C-module, used in the script, caused some problem
>> or is
>> printing the message. This is the case for e.g. r.report (file
>> stats.c)
>> too.
>> What about adding G_program_name(); to every message, so that
>> G_message("Hallo, world!");
>> would produce
>> g.module: Hallo, world!
> Why? This amounts to spam, IMHO. Some module names are 30 characters
> wide (I'm looking at you, r.li)! That's nearly half the terminal
> length.
> r.li's modules need to be renamed in keeping with other modules (mixed
> case, length, etc.). I do not envy anyone who has to use them without
> tab-completion or similar.
this was discussed already and new names were proposed - Serena was
probably
just waiting to get her CVS access approved?
Serena, now that you have the access can you please change the names -
it would be good to do it ASAP before people start using the long
names in their scripts.
as for the message, I tend to agree with jachym on this one, I think
it would be useful to have the module name printed along with the
message -
except for r.li* the modules have quite reasonable names.
Thanks, Helena
> Brad Douglas <rez touchofmadness com> KB8UYR/6
> Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
