[GRASS-dev] G_program_name to every message
Daniel Calvelo
dca.gis at gmail.com
Sun Jan 7 21:24:36 EST 2007
On 1/7/07, Brad Douglas <rez at touchofmadness.com> wrote:
> Oops. I missed a key word when I read it: "debug". Sorry.
:) No harm. Indeed, for debugging purposes, it may give some extra
information at little coding cost.
> On Sun, 2007-01-07 at 18:14 -0800, Brad Douglas wrote:
> > No. The only place that is appropriate is G_debug(). Average users
> > could care less about that information and will likely complain about
> > it.
> > On Sun, 2007-01-07 at 20:42 -0500, Daniel Calvelo wrote:
> > > Hi Jachym. Great idea. I would condition that on the debug environment
> > > variable. You might even consider adding __FILE__ and __LINE__
> > > references then.
> > > Daniel.
> > > On 1/7/07, Jachym Cepicky <jachym.cepicky at centrum.cz> wrote:
> > > > Hallo,
> > > > I think it would be nice, if G_message, G_warning and G_fatal_error
> > > > would print module name at the beginning of the message.
> > > > If the modules are used in scripts, it is sometimes difficult to
> > > > identify, which C-module, used in the script, caused some problem or is
> > > > printing the message. This is the case for e.g. r.report (file stats.c)
> > > > too.
> > > > What about adding G_program_name(); to every message, so that
> > > > G_message("Hallo, world!");
> > > > would produce
> > > > g.module: Hallo, world!
> > > > and
> > > > G_warning("Hallo, world!"); -> WARNING: g.module: Hallo, world!
> > > > The question is, how to do it... Imho the best place is printf_error();
> > > > in error.c
> > > > What do you think?
> Brad Douglas <rez touchofmadness com> KB8UYR/6
> Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
-- Daniel Calvelo Aros
