[GRASS-dev] g.list -a
Glynn Clements
glynn at gclements.plus.com
Fri Jan 12 06:59:51 EST 2007
Martin Landa wrote:
> [snip]
> > > 2) It seems better to add the type 'all' to g.list manually
> > > (especially because of the requested type parameter). I am not sure
> > > how to do it in an elegant way (see the patch) - my approach seems to
> > > be very ugly.
> > I would abandon the approach of having a separate "parse" function in
> > favour of iterating over element->answers and listing each type as
> > it's encountered.
> well, I have tried to simplify the patch. Functions parse() &
> do_list() are now called for each element->answers[i]. I hope it is
> better now.
+ if (G_parser(argc, argv))
+ fprintf (stderr, _("\nWhere %s is one of:\n"), element->key);
+ show_elements();
+ exit(EXIT_FAILURE);
If G_parser() fails, the program should just call exit(EXIT_FAILURE);
G_parser() will print an error message detailing why it failed.
> > lib/do_list.c doesn't need to change; just have cmd/list.c call
> > do_list() once for each type.
> I think that fn do_list() have to be rewritten because of the -f flags
> (calling of execl() fn) ?
No; do_list() can remain untouched, while the handling of -f should
remain essentially the same, except that it should use G_spawn()
instead of execl().
