[GRASS-dev] File based GRASS batch processing?
Markus Neteler
neteler at itc.it
Mon Jan 22 11:26:00 EST 2007
On Mon, Jan 22, 2007 at 05:24:11PM +0100, Florian Kindl wrote:
> On Jan 22 [17:09], Markus Neteler wrote:
> > Before wasting time on this, any suggestions for a best
> > implementation? Maybe I am overlooking an easy solution.
> I use VNC as a workaround: Start vncserver with -localhost option,
> Login with ssh -X and start vncviewer. Then I do the grass job on the
> vnc desktop, which isn't affected by my logging off.
> Is this an option for you?
No, any VNC connection is eaten by our firewall.
> However, the batch processing mode would be good for at/cron jobs, too.
Right. That's why I would prefer a totally decoupled solution.
Markus
