[GRASS-dev] grass start patch
Glynn Clements
glynn at gclements.plus.com
Mon Jan 22 17:24:27 EST 2007
Markus Neteler wrote:
> I wonder if attached patch should be applied (quoting
> of GISBASE path for white space).
> Index: grass.src
> # Set the GISBASE variable
> -GISBASE=GISBASE_VALUE
> +GISBASE="GISBASE_VALUE"
Yes.
This will matter if you want to install GRASS into e.g.
"C:\Program Files" on Windows and start GRASS via the grass63 bash
script rather than grass63.bat.
[The syntax of the command.com/cmd.exe "set" command is different;
everything after the = is the value, regardless of whitespace.]
