[GRASS-dev] grass start patch
Markus Neteler neteler at itc.it
Mon Jan 22 17:42:20 EST 2007
On Mon, Jan 22, 2007 at 10:24:27PM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > I wonder if attached patch should be applied (quoting
> > of GISBASE path for white space).
> > Index: grass.src
> >  # Set the GISBASE variable
> > -GISBASE=GISBASE_VALUE
> > +GISBASE="GISBASE_VALUE"
> Yes.
> This will matter if you want to install GRASS into e.g.
> "C:\Program Files" on Windows and start GRASS via the grass63 bash
> script rather than grass63.bat.
Done: submitted.
Markus
> [The syntax of the command.com/cmd.exe "set" command is different;
> everything after the = is the value, regardless of whitespace.]
> Glynn Clements <glynn at gclements.plus.com>
