[GRASS-dev] File based GRASS batch processing?
Glynn Clements
glynn at gclements.plus.com
Tue Jan 23 01:59:28 EST 2007
Markus Neteler wrote:
> I forgot to mention that I cannot directly ssh to that
> machine but access it only through another ssh gate, then
> with a second ssh I get into it:
> +--- ssh -+ ssh
> me --+-> gate -+--> officebox ---> GRASS machine
> I guess that "screen" doesn't work for this case.
It shouldn't make any difference how you get into the system. Once you
start screen (on the "GRASS machine"), you should be able to reconnect
to the session whenever (and however) you subsequently get in (ssh,
telnet, dial-up login, console login, etc).
