[GRASS-dev] I.points not compiling on Mac
Michael Barton michael.barton at asu.edu
Wed Jan 24 00:26:33 EST 2007
Markus and Glynn,
It happens that i.points won't compile  on my Mac. In discussing this with
William Kyngesbury, he suggests it could be a bug missed in a recent cleanup
of vask and curses.
He also suggests modifying the i.points makefile (see below). Since I know
just enough about make files to really get into trouble, I don't want to
make this change. Can one of you take a quick look and see if this is
something that needs to be done generally or if it is something that is Mac
specific?
Thanks
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
------ Forwarded Message
> From: William Kyngesburye <kyngchaos at kyngchaos.com>
> Date: Mon, 22 Jan 2007 13:57:10 -0600
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Bob Covill <bcovill at accesswave.ca>
> Subject: Re: Nviz still crashing on startup with my compiled binary
>> Related to the xcode project, you opined that the reason that
>> i.points would
>> not compile correctly is because of a libcurses issue. Any
>> suggestion as to
>> how to fix this? If I understood an earlier post of yours, xcode
>> will not go
>> ahead and package GRASS unless everything compiles without error.
> Probably a bug that needs reporting - there was the fuss a while back
> about reducing unnecessary use of vask and curses, and I think curses
> got removed from i.points by mistake.  Though why others (non-OSX
> users) haven't had this problem is a mystery.
> In the i.points makefile add $(CURSES) to LIBES.
------ End of Forwarded Message
