[GRASS-dev] Re: Nviz animation wish
Thu Jan 25 13:58:50 EST 2007
William Kyngesburye wrote:
> A question about the ffmpeg support - is it limited to just the
> mpeg-1 output, or can it use any format supported by ffmpeg?
There is a compile-time option (USE_XVID) to use XviD instead. It
should be straightforward to allow the user to specify the codec by
name; there is already some (commented-out) code which attempts to do
this, although it should be using avcodec_find_encoder_by_name().
See lib/ogsf/gsd_img_ppm.c for details.
