[GRASS-dev] Re: Nviz animation wish
Hamish
hamish_nospam at yahoo.com
Thu Jan 25 20:58:53 EST 2007
Hamish:
> > Again, not needed. r.out.mpeg will work fine with "ppmtompeg" which
> > comes with NetPBM tools. AFAIK this comes with MacOSX already.
> > ppmtompeg is mpeg-encode renamed; r.out.mpeg should work out of
> > the box, ie without ffmpeg.
William:
> No, there are no commandline mpeg tools that come preinstalled with
> OSX.
Hmph. I could have sworn OSX included NetPBM...apparently not. It
would make a great candidate for inclusion the frameworks pacakge,
as several grass scripts use them.
> But some are readily available and up-to-date - ffmpeg,
> mencoder come to mind. You can also find some in Fink and
> Darwinports, but some people prefer to not use those.
Indeed, Lorenzo included a ffmpeg binary and some img2img conversion
programs in his grasslibs/bin/ directory.
Helena:
> nviz will create series of rgb files - I used moviemaker to make them
> into movies on SGI.
fyi, support for SGI's RGB format was removed from NVIZ after GRASS 6.0.2.
Hamish
