[GRASS-dev] r.flow: crash on 64bit
Markus Neteler
neteler at itc.it
Tue Jan 30 08:04:29 EST 2007
Brad Douglas wrote on 01/30/2007 12:45 PM:
> On Mon, 2007-01-29 at 22:39 +0100, Markus Neteler wrote:
>> Hi,
>> when using r.flow on 64bit, it crashes (Spearfish example):
>> r.flow elevation.dem flout=flout lgout=lgout dsout=dsout
>> Reading input files: elevation
>> Precomputing: tangents
>> Precomputing: e/w distances
>> Precomputing: quantization tolerances
>> Precomputing: interpolated border elevations
>> Precomputing: aspects
>> Calculating maps ...
>> Segmentation fault
>> It dies in calc.c:223.
> 'aspin' and 'barin' inputs are apparently not optional. It segv()s
> because the variables point to invalid memory segments.
Brad,
both parameters should be optional. And on 32bit there is no such
problem, it works.
> I take it the module should function with the parameters you used? Let
> me know so I can either track it down or issue the proper error and exit
> gracefully.
I am afraid that it is really a bug somewhere.
Markus
> From first glace, the module could really use a good rewrite. It
> doesn't seem to have been touched (other than minor maintenance) in some
> time. I'm sure the mathematical integrity is in tact, but it is a bit
> confusing to navigate due to long macros that should probably be
> functions and functions that should be combined. Code normally found in
> main() is split up into several functions "daisy chained" together.
> I'll put it at the bottom of my queue for now...
