[GRASS-dev] r.flow: crash on 64bit
Brad Douglas
rez at touchofmadness.com
Tue Jan 30 06:45:19 EST 2007
On Mon, 2007-01-29 at 22:39 +0100, Markus Neteler wrote:
> Hi,
> when using r.flow on 64bit, it crashes (Spearfish example):
> r.flow elevation.dem flout=flout lgout=lgout dsout=dsout
> Reading input files: elevation
> Precomputing: tangents
> Precomputing: e/w distances
> Precomputing: quantization tolerances
> Precomputing: interpolated border elevations
> Precomputing: aspects
> Calculating maps ...
> Segmentation fault
> It dies in calc.c:223.
'aspin' and 'barin' inputs are apparently not optional. It segv()s
because the variables point to invalid memory segments.
I take it the module should function with the parameters you used? Let
me know so I can either track it down or issue the proper error and exit
gracefully.
>From first glace, the module could really use a good rewrite. It
doesn't seem to have been touched (other than minor maintenance) in some
time. I'm sure the mathematical integrity is in tact, but it is a bit
confusing to navigate due to long macros that should probably be
functions and functions that should be combined. Code normally found in
main() is split up into several functions "daisy chained" together.
I'll put it at the bottom of my queue for now...
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
