[GRASS-dev] time to release 6.2.2
Paul Kelly paul-grass at stjohnspoint.co.uk
Sun Jul 1 16:13:48 EDT 2007
Hello Markus
As I noted before
(http://grass.itc.it/pipermail/grass-dev/2007-May/031699.html) Grass 6.2.2
seems to already be tagged (as grass_6_2_2) in CVS. I wonder how/when this
happened, but it was definitely before 28th May as that was when I sent
that e-mail. I still think it is a good idea to include the date of
releases in the tag name, less confusion that way, e.g.
release_20070702_grass_6_2_2 - what do you think? Or is there any other
way of telling from CVS on what date the tag was created?
Paul
On Sun, 1 Jul 2007, Markus Neteler wrote:
> Hi,
> during the testing period of 6.2.2-RC1 we got the following
> issues fixed:
>    * DBF driver: fix semicolon problem  (Glynn Clements)
>    * SQLite transactions to speed up execute (Antonio Galea)
>    * GUI startup: fixes browsing for EPSG file not updating path to it (Maris Nartiss)
>    * GUI startup: fixes browsing for new location path (Maris Nartiss)
>    * nviz compilation fix for MacOSX (Markus Neteler)
>    * r.in.gdalwarp: remove bashisms (Hamish Bowman)
>    * v.dissolve: fix for DBMI error if input map is specified with @mapset (Markus Neteler)
>    * v.lrs.* fixes backported + new documentation (Markus Neteler)
>    * Czech translation updated (Jachym Cepicky)
> See
> http://grass.gdf-hannover.de/wiki/GRASS_6.2_Feature_Plan#Fixed_post-RC1
> I would suggest to release 6.2.2 officially the next days if nobody
> objects.
> Markus
> Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
> FBK-irst -  Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
