[GRASS-dev] DBF driver: semicolon and select troubles
Glynn Clements
glynn at gclements.plus.com
Sun Jul 1 23:31:39 EDT 2007
Markus Neteler wrote:
> Unrelated: I get these warnings on Mandriva:
> bison -y -d -v yac.y
> yac.y:74.15-19: Warnung: symbol TABLE redeclared
> yac.y:75.8-11: Warnung: symbol DROP redeclared
> yac.y:75.13-17: Warnung: symbol TABLE redeclared
> bison --version
> bison (GNU Bison) 2.3
> It this harmful?
I don't think so. They've always been there, and they're due to:
63 %token DROP
73 %token ALTER TABLE
74 %token CREATE TABLE
75 %token DROP TABLE
DROP is defined on 63 then defined again on 75. TABLE is defined on 73
then again on 74 and 75. A %token directive with multiple tokens is
exactly equivalent to multiple %token directives.
You can eliminate the warnings with:
--- lib/db/sqlp/yac.y 1 Jul 2007 08:52:49 -0000 1.28
+++ lib/db/sqlp/yac.y 2 Jul 2007 03:30:05 -0000
@@ -71,8 +71,7 @@
%token OR
%token NOT
%token ALTER TABLE
-%token CREATE TABLE
-%token DROP TABLE
+%token CREATE
%token NULL_VALUE
%token VARCHAR
%token INT
