[GRASS-dev] Re: gis.m/geocoding tool broken?
Michael Barton
michael.barton at asu.edu
Mon Jul 2 17:43:23 EDT 2007
Found and fixed this. Now in the CVS
What I think happened is that several months ago, it became (or I learned
that it was) no longer necessary to set and unset GRASS_RENDER_IMMEDIATE for
the GUI. Just set it and leave it set. I took this out of the main GUI code
(mapcanvas.tcl), but forgot to take it out of the georect.tcl code (which
does a replication of the same rendering commands to display a georect map.
the result was that every time you displayed a map in the georectifier
window, it would set, then UNSET GRASS_RENDER_IMMEDIATE. With this
environmental variable unset, the main GUI (which no longer set and unset
this variable at each display) was looking for a driver for outputting the
display.
I took this unnecessary code out of georect.tcl and it all works fine.
***How can I find out if this needs to be backported to 6.2.2?******
It WILL need to be backported if the command to set/unset
GRASS_RENDER_IMMEDIATE has been removed from mapcanvas.tcl. If this command
is still in mapcanvas.tcl, georect.tcl ALSO needs this command (i.e., what I
just removed).
Michael
On 7/2/07 9:53 AM, "Markus Neteler" <neteler at itc.it> wrote:
> Michael,
> On Mon, Jul 02, 2007 at 09:49:53AM -0700, Michael Barton wrote:
>> Markus,
>> The error you get indicates that the PNG driver has been 'turned off'. There
>> is no clue in the list of commands you sent as to why this is so. Do you
>> have the TclTk error message?
> I'll try to generate it again but it was than x0 isn't found (I think
> as in the error log).
>> Today is kind of busy, but I'll try to do some testing here as soon as I
>> can.
> thanks!
> markus
>> Michael
>> On 7/1/07 1:02 PM, "Markus Neteler" <neteler at itc.it> wrote:
>>> Michael,
>>> this evening I wanted to update the geocoding section
>>> in the upcoming GRASS book, but it failed... Some weeks
>>> ago I co-registered two raster maps successfully, today
>>> I tried the first time to register against a geocoded
>>> vector map. It fails to find the tcl "monitor", see error.log
>>> attached.
>>> I would be gratefule if you could take a look.
>>> thanks
>>> markus
>>> ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
>>> ITC -> since 1 March 2007 Fondazione Bruno Kessler
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> Director of Graduate Studies
>> School of Human Evolution & Social Change
>> Center for Social Dynamics and Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
phone: 480-965-6213
fax: 480-965-7671
