[GRASS-dev] time to release 6.2.2
Markus Neteler neteler at itc.it
Fri Jul 6 11:30:21 EDT 2007
Carlos Dávila wrote on 07/06/2007 12:49 PM:
> Markus Neteler escribió:
>>>> Hi,
>>>> during the testing period of 6.2.2-RC1 we got the following
>>>> issues fixed:
>>>>     * Czech translation updated (Jachym Cepicky)
>>> What about the other languages? Will they be included in the new
>>> release and packages?
>>> Carlos
>> Carlos,
>> would be great to merge back. But I tried once and actually *lost*
>> many messages. So, after a try one must check if this doesn't
>> reduce the translations in 6.2.x.
>> I can send you a script "po_merge.sh" which does it for all 3 files
>> automatically The script will ask you for the country code and then
>> it uses "msgmerge". The script is just a few lines.
> I already had the script. I've done a test with es.po files and this
> is the result:
> libs: same total and more fuzzy, so discarded.
> mods and tcl: total amount of messages raises from 3910 and 871 to
> 4775 and 1148 respectively. Are all these new messages useful in 6.2.2
> or I shall look only to the variation in fuzzy and untranslated? Shall
> I make pot & make update-po after running the script?
> As you can see, many doubts.
I think that only "good" messages count (so, translated, non-fuzzy) and the
rest isn't important. If you observe a growing number of correctly
translated messages,
then I suggest to submit to 6.2.cvs.
Markus
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
