[GRASS-dev] How to specify custom include directories
David Finlayson
dfinlayson at usgs.gov
Wed Jul 11 19:18:57 EDT 2007
First time compiling GRASS on SuSE. I do not have su privileges on this
machine and so I am forced to build my entire tool chain in my home
directory ($HOME)=/we/davidf).
So far fftw-3.1.2, gdal-1.4.2 and proj-4.5.0 have all compiled using the
following:
./configure --prefix=$HOME
make
make install
Which has built a directory tree in $HOME like this:
$HOME/bin
$HOME/include
$HOME/lib
$HOME/man
$HOME/share
Now, trying the same with grass results in a configure error:
albacore src/grass-6.2.cvs_src_snapshot_2007_07_07> ./configure
--prefix=$HOME --enable-64bit --with-libs=/usr/lib64
checking host system type... x86_64-unknown-linux-gnu
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
... etc ...
checking for deflate in -lz... yes
checking for location of External PROJ.4 includes...
checking for proj_api.h... no
configure: error: *** Unable to locate External PROJ.4 includes.
However, proj_api.h is in $HOME/include
I have tried adding --includedir=$HOME/include to the above but that didn't
change anything. I'm sure it's something simple. How do I tell configure
where my local includes are (and why didn't --prefix=$HOME work?)
Thanks,
David Finlayson, Ph.D.
Operational Geologist
U.S. Geological Survey
Pacific Science Center
400 Natural Bridges Drive
Santa Cruz, CA 95060, USA
Tel: 831-427-4757, Fax: 831-427-4748, E-mail: dfinlayson at usgs.gov
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070711/26199214/attachment.html
