[GRASS-dev] How to specify custom include directories
Helena Mitasova hmitaso at unity.ncsu.edu
Wed Jul 11 19:37:16 EDT 2007
David,
this is the configure I use to compile GRASS with everything (gdal,
proj and grass, all CVS versions)
in my home directory:
CFLAGS="-g -Wall" ./configure \
--prefix=/local/home/helena/grassdev \
--with-cxx \
--enable-64bit --with-libs=/usr/lib64 --enable-largefile --enable-
shared \
--with-bindir=/local/home/helena/grassdev \
--with-gdal=/local/home/helena/gsgdal/bin/gdal-config \
--with-gdal-includes=/local/home/helena/gsgdal/include \
--with-gdal-libs=/local/home/helena/gsgdal/lib \
--with-proj=yes \
--with-proj-includes=/local/home/helena/gproj/include \
--with-proj-libs=/local/home/helena/gproj/lib \
--with-proj-share=/local/home/helena/gproj/share/proj \
--with-motif \
--with-python
I also had to add the path here (advice from Markus):
system-wide add it to (if you can use sudo )
   /etc/ld.so.conf
Then run
ldconfig
solution just for your login:
modify $HOME/.bashrc or $HOME/.cshrc depending on your shell
and define it there. The GRASS path is added automatically,
so just add /home/helena/gdal/lib there (or in /etc/ld.so.conf).
I have been compiling and running the GRASS CVS version from home
directory for years so hopefully it will work for you too,
Helena
Helena Mitasova
Dept. of Marine, Earth and Atm. Sciences
1125 Jordan Hall, NCSU Box 8208,
Raleigh NC 27695
http://skagit.meas.ncsu.edu/~helena/
On Jul 11, 2007, at 7:18 PM, David Finlayson wrote:
> First time compiling GRASS on SuSE. I do not have su privileges on
> this machine and so I am forced to build my entire tool chain in my
> home directory ($HOME)=/we/davidf).
> So far fftw-3.1.2, gdal-1.4.2 and proj-4.5.0 have all compiled
> using the following:
> ./configure --prefix=$HOME
> make
> make install
> Which has built a directory tree in $HOME like this:
> $HOME/bin
> $HOME/include
> $HOME/lib
> $HOME/man
> $HOME/share
> Now, trying the same with grass results in a configure error:
> albacore src/grass-6.2.cvs_src_snapshot_2007_07_07> ./configure --
> prefix=$HOME --enable-64bit --with-libs=/usr/lib64
> checking host system type... x86_64-unknown-linux-gnu
> checking for gcc... gcc
> checking whether the C compiler (gcc  ) works... yes
> ... etc ...
> checking for deflate in -lz... yes
> checking for location of External PROJ.4 includes...
> checking for proj_api.h... no
> configure: error: *** Unable to locate External PROJ.4 includes.
> However, proj_api.h is in $HOME/include
> I have tried adding --includedir=$HOME/include to the above but
> that didn't change anything.  I'm sure it's something simple. How
> do I tell configure where my local includes are (and why didn't --
> prefix=$HOME work?)
> Thanks,
> David Finlayson, Ph.D.
> Operational Geologist
> U.S. Geological Survey
> Pacific Science Center
> 400 Natural Bridges Drive
> Santa Cruz, CA  95060, USA
> Tel: 831-427-4757, Fax: 831-427-4748, E-mail: dfinlayson at usgs.gov
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
