[GRASS-dev] ramdisk as mapset?
David Finlayson dfinlayson at usgs.gov
Fri Jul 20 16:09:55 EDT 2007
What about running GRASS in something like Xgrid or Grid Engine?
I am about to purchase a cluster of Mac Pros for filtering and
rendering sonar data and I have been curious what has been done to
parallelize GRASS buy enterprising people. Grass isn't threaded so it
might work well on a cluster if you can keep the nodes fed with data.
Maybe some Franken-script could divide the raster data into segments
and launch a node on each segment.
I read a paper recently that documented using GRASS on GeoWalls via a
series of shell scripts that controlled the batch processing, but I
haven't looked into it in detail and can't remember the authors off
the top of my head.
Our data sets are toping 100 million points a piece and I am looking
for ways to divide and conquer the work load. Currently, I use GMT
across 8 nodes and it works well (if a bit clunky as far as job
management goes).
David
On 7/19/07, Glynn Clements <glynn at gclements.plus.com> wrote:
> "Sören Gebbert" wrote:
> > interesting idea. But lets put this idea into the library of grass. :)
> > I would like to suggest to extent the grass lib to
> > read the entire map into the memory if needed.
> There's no advantage if you're doing sequential I/O, which is most of
> GRASS.
> Programs which do random I/O already have mechanisms to deal with
> this; e.g. r.proj reads the entire useful region into memory,
> r.proj.seg has its own tile cache, other programs (e.g. r.cost) use
> the segment library.
> If you are concerned about efficiency, build GRASS with profiling
> support, and look at where the actual inefficiency lies. It would help
> to do the same for 4.x, as that is reported to be an order of
> magnitude faster than 5.x/6.x for some tasks.
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
David Finlayson, Ph.D.
Operational Geologist
U.S. Geological Survey
Pacific Science Center
400 Natural Bridges Drive
Santa Cruz, CA  95060, USA
Tel: 831-427-4757, Fax: 831-427-4748, E-mail: dfinlayson at usgs.gov
