[GRASS-dev] [grass-code I][431] g.copy segmentation fault
Volker Wichmann wichmann at laserdata.at
Mon Jul 23 02:40:51 EDT 2007
Digging a little deeper, I found that the return values of the two
'open' commands (variables fd and fd2) are reasonable - but what about
the return value of the read command (line 146, do_copy.c):
len = read(fd, buf, 1024)
Why is a 0 returned at the first call - my dataset is a valid raster, so
why an EOF before reading anything?
Maybe this is an issue of file permission? Any help is appreciated!
Thanks,
Volker
Volker Wichmann wrote:
> Hi,
> discussing this topic off-list it showed up that this topic is NOT
> solved so far. I encounter the same error with a cvs install from
> scratch (about 2 weeks old).
> I tried some debugging, that's what I found:
> do_copy.c (in .../general/manage/lib) seems to produce the segfault,
> especially the function recursive_copy. I can't catch the return value
> of this function as the segfault happens immediately after returning
> from this function.
> Within recursive_copy the /* src is a file */ section is entered, and
> all "if" queries and "while" loops are simply passed.  The variables
> that get set have the following values:
> fd = 3
> fd2 = 4
> len = 0
> Any ideas?
> Thanks,
> Volker
> Maciej Sieczka wrote:
>>> example
>>> g.copy rast=objekthoehen20,muell10
>>> Copy raster <objekthoehen20 at testdaten> to current mapset as <muell10>
>>> Speicherzugriffsfehler
>> It showed to be problem due to two conflicting GRASS 6.3 instalations.
>> Case closed.
>> Maciek
>> grass-dev mailing list
>> grass-dev at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass-dev
