[GRASS-dev] d.font -l: please sort alphabetically
Markus Neteler
neteler at itc.it
Wed Jul 25 16:21:47 EDT 2007
Glynn Clements wrote:
> Paul Kelly wrote:
>> - Glynn mentioned that adding a d.font -L flag (capital L rather than
>> lower-case l) might be a good idea for that. It isn't entirely simple
>> though, but just needs some work. Do you think that would be enough? Or
>> should we change the search to sort on the short name -
>> case-insensitively
>> perhaps? You could try that if you want and see if it gives you good
>> results on your system - just change the two references to "longname" in
>> that function to "name".
>> I'm not sure how much info the d.font -L flag should produce though -
>> just
>> the short name and long name, or the path to the file, index within the
>> file etc.?
> I've added R_font_info(), which behaves like R_font_list() except that
> each string is the entire fontcap entry rather than just the name.
> I've also added a -L switch to d.font. Currently, this dumps the raw
> string (with fields separated by the | character); some formatting
> would probably be desirable.
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Glynn,
I have tried but both -l and -L don't report anything (any more).
Doing a bit of debugging, I found that num_fonts is zero in
print_font_list() at:
for (i = 0; i < num_fonts; i++)
But
wc -l $GISBASE/etc/fontcap
268 /home/neteler/soft/63grass_cvsexp/dist.i686-pc-linux-gnu/etc/fontcap
The debugger doesn't step into read_freetype_fonts(), not sure why (maybe
due to my lack of knowledge of ddd/gdb).
I didn't run "make distclean" if that matters.
Markus
View this message in context: http://www.nabble.com/d.font--l%3A-please-sort-alphabetically-tf4138371.html#a11799136
Sent from the Grass - Dev mailing list archive at Nabble.com.
