[GRASS-dev] Re: [STATSGRASS] cant read raster created with
r.neighbours
Glynn Clements
glynn at gclements.plus.com
Thu Jul 26 17:38:51 EDT 2007
Roger Bivand wrote:
> CC-ed to GRASS-dev, short file name buffer issue in
> raster/r.out.bin/main.c line 225:
> Yes, because a shorter file name buffer is declared on line 225 of main.c
> in r.out.bin - with a length of 100, so fname fits, but the header
> overwrites it, I think - could I suggest that the lengths of the out_bufs
> in line 255 be set to [GNAME_MAX] instead?
GPATH_MAX is the standard constant for pathnames.
Fixed in CVS.
