[GRASS-dev] Re: [STATSGRASS] cant read raster created with
r.neighbours
Markus Neteler
neteler at itc.it
Fri Jul 27 01:44:41 EDT 2007
Glynn Clements wrote:
> Markus Neteler wrote:
>> I have fixed the r.out.bin buffer issue in CVS (also in 6.2.3-CVS).
> This should be changed to GPATH_MAX (the parameter is a pathname, not
> a map name); but first, GPATH_MAX needs to be added to 6.2.
Both done in 6.2.3-CVS (will appear in 6.2.3).
Markus
View this message in context: http://www.nabble.com/Re%3A--STATSGRASS--cant-read-raster-created-with-r.neighbours-tf4153115.html#a11823290
Sent from the Grass - Dev mailing list archive at Nabble.com.
