Markus Neteler wrote: > I have fixed the r.out.bin buffer issue in CVS (also in 6.2.3-CVS). This should be changed to GPATH_MAX (the parameter is a pathname, not a map name); but first, GPATH_MAX needs to be added to 6.2. -- Glynn Clements <glynn at gclements.plus.com>
