[GRASS-dev] [grass-code I][448] i.taget missing in tcltk tool georeferencing
Michael Barton michael.barton at asu.edu
Thu Jul 26 18:14:24 EDT 2007
This has been resolved but I didn't see any information posted back to the
dev list.
To clarify, with the new TclTk georectifying tool, you start out in the
'target' region and georectify INTO it. Hence, you don't need to specify a
target region.
Michael
On 7/26/07 1:31 AM, "grass-codei at wald.intevation.org"
<grass-codei at wald.intevation.org> wrote:
> code I item #448, was opened at 2007-07-26 08:31
> Status: Open
> Priority: 3
> Submitted By: Otto Dassau (dassau)
> Assigned to: Nobody (None)
> Summary: i.taget missing in tcltk tool georeferencing
> Issue type: None
> Issue status: None
> GRASS version: 6.2
> GRASS component: tcl/tk GUI
> Operating system: Linux
> Operating system version: debian testing
> GRASS CVS checkout date, if applies (YYMMDD):
> Initial Comment:
> Hi,
> the tcltk menue "GRASS georectifier" in GRASS 6.2.2 needs a button for i.taget
> to define the target location. Currently it includes:
> 1) choose mapset
> 2) create/edit group
> 3) select group
> 4) select map
> 5) georectify
> error message is:
> child process exited abnormally
>     while executing
> "exec -- i.rectify -ca group=muell extension=6856 order=1 >& /dev/null"
>     ("eval" body line 1)
>     invoked from within
> "eval [list exec -- $cmd] $args >& $devnull"
>     (procedure "run" line 12)
>     invoked from within
> "run i.rectify -ca group=muell extension=6856 order=1"
>     invoked from within
> "eval run $cmd $args"
>     (procedure "runcmd" line 6)
>     invoked from within
> "runcmd $cmd"
>     (procedure "GRMap::rectify" line 54)
>     invoked from within
> "GRMap::rectify"
>     ("uplevel" body line 1)
>     invoked from within
> "uplevel \#0 $cmd"
>     (procedure "Button::_release" line 18)
>     invoked from within
> "Button::_release .gcpwin.mf.topf.tb0.bbox1.b3"
>     (command bound to event)
> defining it manually works of course
> i.target -c group=muell
> regards,
>  Otto
> You can respond by visiting:
> http://wald.intevation.org/tracker/?func=detail&atid=204&aid=448&group_id=21
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
