[GRASS-dev] d.out.file and d.font issue
Glynn Clements
glynn at gclements.plus.com
Tue Jul 31 00:27:00 EDT 2007
Markus Neteler wrote:
> I tried to make a nice GRASS monitor dump with d.out.file but
> realized that the freetype fonts are only approximated:
> # spearfish
> g.region rast=elevation.dem -p
> d.mon x0
> d.font FreeSans
> d.rast elevation.dem
> echo "Spearfish elevation" | d.text col=black
> # ... looks nice
> d.out.file demo res=2 format=png
> # ... looks say, different
> This is probably know - or is it a non-feature?
> (Un ?)related: a monitor de-/reselect doesn't make survive the
> font selection:
> d.mon x0
> d.font FreeSans
> # ... looks nice
> d.mon x1
> d.mon sel=x0
> d.redraw # or resize
> Probably the d.out.file problem is related to this. Does D_add_to_list()
> fail or
> something like that?
Unless called with -o, d.rast erases the screen, which removes the
font setting (the monitor remembers the actual font setting, but the
information is removed from the "pads", which is what d.save uses):
[display/d.rast/display.c lines 38-40]
/* cell maps wipe out a picture, so we clear info on the window too */
if (!overlay)
D_clear_window();
Try running d.font *after* d.rast.
