[GRASS-dev] d.out.file and d.font issue
Markus Neteler
neteler at itc.it
Tue Jul 31 03:52:38 EDT 2007
Glynn Clements wrote:
> Markus Neteler wrote:
>> I tried to make a nice GRASS monitor dump with d.out.file but
>> realized that the freetype fonts are only approximated:
>> # spearfish
>> g.region rast=elevation.dem -p
>> d.mon x0
>> d.font FreeSans
>> d.rast elevation.dem
>> echo "Spearfish elevation" | d.text col=black
>> # ... looks nice
>> d.out.file demo res=2 format=png
>> # ... looks say, different
>> This is probably know - or is it a non-feature?
>> (Un ?)related: a monitor de-/reselect doesn't make survive the
>> font selection:
>> d.mon x0
>> d.font FreeSans
>> # ... looks nice
>> d.mon x1
>> d.mon sel=x0
>> d.redraw # or resize
>> Probably the d.out.file problem is related to this. Does D_add_to_list()
>> fail or
>> something like that?
> Unless called with -o, d.rast erases the screen, which removes the
> font setting (the monitor remembers the actual font setting, but the
> information is removed from the "pads", which is what d.save uses):
> [display/d.rast/display.c lines 38-40]
> /* cell maps wipe out a picture, so we clear info on the window too */
> if (!overlay)
> D_clear_window();
> Try running d.font *after* d.rast.
Glynn, is there a reason to wipe the font out in D_clear_window()? I would
set if for the entire session (or longer) (otherwise use d.font again).
If it is due to technical constraints, should I modify the d.redraw/d.out.*
to first grab the font setting and then restore it after d.erase?
I would like to avoid that I have to hack a couple of GRASS scripts
locally to keep the font setting in the monitor.
Markus
View this message in context: http://www.nabble.com/d.out.file-and-d.font-issue-tf4169926.html#a11919720
Sent from the Grass - Dev mailing list archive at Nabble.com.
