[GRASS-dev] QGIS winGRASS blank space problem
Glynn Clements
glynn at gclements.plus.com
Mon Jun 4 12:09:53 EDT 2007
Paul Kelly wrote:
> > a friend told me that with the latest QGIS release candidate,
> > there is a winGRASS problem:
> > $ v.rast.stats vector=CEA_riserve raster=CEA_slope colprefix=delete
> > c:/Programmi/Quantum: c:/Programmi/Quantum: No such file or directory
> v.rast.stats is a shell script, so you are likely to have loads of
> problems if not finding it nearly impossible to get it working properly on
> Windows. I notice there are loads of places in it that paths aren't
> quoted so that is probably the first problem (although to be fair that is
> also a problem for Unix and isn't a problem for Windows if you don't
> install software in paths with spaces in them!).
That's certainly a fundamental problem; $TMP and $SQLTMP appear to be
the most likely candidates.
Regardless of Windows-specific issues, failure to quote variables
which contain pathnames is a bug and needs to be fixed.
AFAICT, $SQLTMP is unnecessary. You can just as easily use a subshell
with its output piped directly to db.execute; no need for a temporary
file.
> Then there is the fact that Msys doesn't understand Windows-style paths,
That's incorrect; MSys itself understands Windows paths, with either a
forward or backward slash.
However, there may be individual scripts which can't handle this.
> In general it's a pleasant surprise if some shell scripts to happen to
> work OK on Windows, and IMHO shouldn't really be considered a bug if they
> don't. I feel the fact that QGIS includes a copy of Msys with GRASS gives
> the "illusion" of GRASS being more compatible with Windows than it really
> is - the truly native WinGRASS we're working on is a more accurate
> expression of GRASS's compatiblity with Windows as I see it.
Ultimately, if we're serious about GRASS on Windows, we need to make
it a priority to migrate away from Bourne shell to something more
portable (with Python being the obvious choice).
