[GRASS-dev] g.gisenv in gui
Hamish
hamish_nospam at yahoo.com
Fri Jun 8 02:34:29 EDT 2007
Michael Barton wrote:
> Found another minor item that a small change could improve.
> g.gisenv does not behave like other GRASS commands in that you cannot
> launch the autogenerated gui by typing g.gisenv¹ from the command
> line. Instead, you get the current environment settings. You can only
> get the gui if you run it through some special processing in the GUI.
for a GUI just launch with:
g.gisenv --ui
use that as the menu command.
A number of modules work like this without command line args.
> Likewise, you can¹t get it to print out current environment settings
> from the gui unless you do some tricks with its execution.
g.gisenv store="" --ui
[Run]
Probably a nice GUI frontend should be used for that, vs exposing the
user to the raw g.gisenv GUI.
Hamish
