[GRASS-dev] g.gisenv in gui
Michael Barton
Michael.Barton at asu.edu
Fri Jun 8 02:55:50 EDT 2007
Hamish,
Thanks for this info. But...
On 6/7/07 11:34 PM, "Hamish" <hamish_nospam at yahoo.com> wrote:
> for a GUI just launch with:
> g.gisenv --ui
This does work to get the gui from the command line
> use that as the menu command.
> A number of modules work like this without command line args.
>> Likewise, you can¹t get it to print out current environment settings
>> from the gui unless you do some tricks with its execution.
> g.gisenv store="" --ui
> [Run]
This doesn't work to get the settings printed to stdout. It just launches
the gui.
Michael
> Probably a nice GUI frontend should be used for that, vs exposing the
> user to the raw g.gisenv GUI.
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
