[GRASS-dev] Re: [GRASSGUI] silly question - running a python script
Sun Jun 10 16:36:14 EDT 2007
Michael Barton wrote:
> I forgot, to send the script. Here it is. Doesn't work and I haven't updated
> main to use a list. But maybe a starting place for figuring out how to do
> scripting with python and GRASS.
If I comment out the "import wx" and "import rules", then both:
	python rules_colors.py --interface-description
and:
	chmod +x rules_colors.py
	./rules_colors.py --interface-description
work fine. Ditto for --help etc.
That indicates that the use of g.parser is okay.
BTW, what's the point of using:
	#!/usr/bin/env python
rather than:
	#!/usr/bin/python
AFAICT, using env in this way is a no-op.
