[GRASS-dev] GRASS and GDAL 1.4.1 MingW
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Fri Jun 15 08:32:41 EDT 2007
It's pretty complex code with additional external dependencies and most
of my archaeological colleagues simply don't have the technical know how
to get it running from a source repository.
This was the original reason why I created GEM which now comes with the
current GRASS in CVS. Since I don't have the time to maintain my code
in several repositories, I will maintain it only in GEM packages.
In the near future, I want to make these work on MingW, as well, but for
now I need a quicker solution because I want to use the software in a
class this semester.
Gerald Nelson wrote:
> Any reason not to add your archeology modules to the set of grass addons?
> ---- Original message ----
>> Date: Fri, 15 Jun 2007 14:08:56 +0200
>> From: Benjamin Ducke <benjamin.ducke at ufg.uni-kiel.de>
>> Subject: Re: [GRASS-dev] GRASS and GDAL 1.4.1 MingW
>> Cc: GRASS devel <grass-dev at grass.itc.it>
>> Two reasons:
>> a) I want to be sure that I understand all details involved in the
>> compile process under MingW
>> b) I have a lot of custom code that I need to merge into the current
>> CVS tree and compile along with it, as GEM does not yet run w/o problems
>> with the MSYS based version of GRASS
>> ... my ultimate goal is to create a version of the current CVS of GRASS
>> 6.3 for use in archaeology. This will include all the additional modules
>> I have written for GRASS over the years.
>> But I will also keep testing your CVS packages as time allows.
>> Benjamin
>> Moritz Lennert wrote:
>>> On 12/06/07 12:35, Benjamin Ducke wrote:
>>>> Hi all,
>>>> concerning the troubles with the DBF driver under Win32 that I wrote
>>>> about earlier, I am trying to compile a current version of GRASS
>>>> with MingW.
>>> Just out of curiosity: any reason you do not wish to use the precompiled
>>> version available at:
>>> http://moritz.homelinux.org/grass/wingrass/
>>> I try to be more or less regular in providing packages based on the
>>> latest CVS (although the latest one is ten days old...I'll put up a new
>>> one tonight or tomorrow).
>>> Moritz
>> Benjamin Ducke, M.A.
>> Archäoinformatik
>> (Archaeoinformation Science)
>> Institut für Ur- und Frühgeschichte
>> (Inst. of Prehistoric and Historic Archaeology)
>> Christian-Albrechts-Universität zu Kiel
>> Johanna-Mestorf-Straße 2-6
>> D 24098 Kiel
>> Germany
>> Tel.: ++49 (0)431 880-3378 / -3379
>> Fax : ++49 (0)431 880-7300
>> www.uni-kiel.de/ufg
>> grass-dev mailing list
>> http://grass.itc.it/mailman/listinfo/grass-dev
> Gerald Nelson
> Professor, Dept. of Agricultural and Consumer Economics
> University of Illinois, Urbana-Champaign
> office: 217-333-6465
> cell: 217-390-7888
> 315 Mumford Hall
> 1301 W. Gregory
> Urbana, IL 61801
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
