[GRASS-dev] GRASS and GDAL 1.4.1 MingW
Gerald Nelson gnelson at uiuc.edu
Fri Jun 15 08:21:22 EDT 2007
Any reason not to add your archeology modules to the set of grass addons?
---- Original message ----
>Date: Fri, 15 Jun 2007 14:08:56 +0200
>From: Benjamin Ducke <benjamin.ducke at ufg.uni-kiel.de>
>Subject: Re: [GRASS-dev] GRASS and GDAL 1.4.1 MingW
>Cc: GRASS devel <grass-dev at grass.itc.it>
>Two reasons:
>a) I want to be sure that I understand all details involved in the
>compile process under MingW
>b) I have a lot of custom code that I need to merge into the current
>CVS tree and compile along with it, as GEM does not yet run w/o problems
>with the MSYS based version of GRASS
>... my ultimate goal is to create a version of the current CVS of GRASS
>6.3 for use in archaeology. This will include all the additional modules
>I have written for GRASS over the years.
>But I will also keep testing your CVS packages as time allows.
>Benjamin
>Moritz Lennert wrote:
>> On 12/06/07 12:35, Benjamin Ducke wrote:
>>> Hi all,
>>> concerning the troubles with the DBF driver under Win32 that I wrote
>>> about earlier, I am trying to compile a current version of GRASS
>>> with MingW.
>> Just out of curiosity: any reason you do not wish to use the precompiled
>> version available at:
>> http://moritz.homelinux.org/grass/wingrass/
>> I try to be more or less regular in providing packages based on the
>> latest CVS (although the latest one is ten days old...I'll put up a new
>> one tonight or tomorrow).
>> Moritz
>Benjamin Ducke, M.A.
>Archäoinformatik
>(Archaeoinformation Science)
>Institut für Ur- und Frühgeschichte
>(Inst. of Prehistoric and Historic Archaeology)
>Christian-Albrechts-Universität zu Kiel
>Johanna-Mestorf-Straße 2-6
>D 24098 Kiel
>Germany
>Tel.: ++49 (0)431 880-3378 / -3379
>Fax : ++49 (0)431 880-7300
>www.uni-kiel.de/ufg
>_______________________________________________
>grass-dev mailing list
>http://grass.itc.it/mailman/listinfo/grass-dev
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
