[GRASS-dev] d.extend in gui
Michael Barton michael.barton at asu.edu
Fri Jun 15 14:00:52 EDT 2007
On 6/14/07 5:17 PM, "Paul Kelly" <paul-grass at stjohnspoint.co.uk> wrote:
> I've mentioned this before but I really think there should be a GUI region
> setting widget with all the functionality of the old interactive
> curses-based g.region. Someone was complaining recently that there should
> be a quick resolution adjust facility in the GUI monitor displays - I
> think that would be a hack but a button to access the interactive region
> setting widget, with further buttons there to save the region as the
> active display region or the mapset working region etc. would be very
> useful IMHO.
Exactly such a location setting wizard is about 80% completed for the
wxPython gui.
Problem: g.proj won't accept g.setproj style values that can pulled from the
projection, transform, and other files in $GISBASE/etc, no will it take
extents. And g.setproj won't run non-interactively.
So we can (and have) replicate everything *except* actually using the values
to create a location.
Can either g.proj be extended to accept g.setproj-like values or g.setproj
get an option to run non-interactively?
Then we could finish the wizard. It runs with the wxgrass startup, so you
can see where it's at currently.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
