[GRASS-dev] Problems posting to grass-gui
Michael Barton
michael.barton at asu.edu
Fri Jun 15 14:19:03 EDT 2007
Glynn,
I had the same problem. It's grassgui at grass.itc.it, not
grass-gui at grass.itc.it.
Michael
On 6/15/07 10:25 AM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> Any idea why my attempts to post to grass-gui keep bouncing?
>> This is a MIME-encapsulated message
>> --l5FGLYOc018107.1181924494/cerise.gclements.plus.com
>> The original message was received at Fri, 15 Jun 2007 17:21:31 +0100
>> from localhost [127.0.0.1]
>> ----- The following addresses had permanent fatal errors -----
>> <grass-gui at grass.itc.it>
>> (reason: 550 5.1.1 <grass-gui at grass.itc.it>... User unknown)
>> ----- Transcript of session follows -----
>> ... while talking to grass.itc.it.:
>>>>> DATA
>> <<< 550 5.1.1 <grass-gui at grass.itc.it>... User unknown
>> Content-Type: message/delivery-status
>> Reporting-MTA: dns; cerise.gclements.plus.com
>> Received-From-MTA: DNS; localhost
>> Arrival-Date: Fri, 15 Jun 2007 17:21:31 +0100
>> Final-Recipient: RFC822; grass-gui at grass.itc.it
>> Action: failed
>> Status: 5.1.1
>> Remote-MTA: DNS; grass.itc.it
>> Diagnostic-Code: SMTP; 550 5.1.1 <grass-gui at grass.itc.it>... User unknown
>> Last-Attempt-Date: Fri, 15 Jun 2007 17:21:34 +0100
>> Content-Type: message/rfc822
>> Return-Path: <glynn at cerise.gclements.plus.com>
>> Received: from cerise.gclements.plus.com (localhost [127.0.0.1])
>> by cerise.gclements.plus.com (8.13.7/8.13.7) with ESMTP id l5FGLVOc018105;
>> Received: (from glynn at localhost)
>> by cerise.gclements.plus.com (8.14.0/8.14.0/Submit) id l5FGLVw7018102;
>> From: Glynn Clements <glynn at gclements.plus.com>
>> MIME-Version: 1.0
>> Content-Type: text/plain; charset=us-ascii
>> Content-Transfer-Encoding: 7bit
>> Message-ID: <18034.48267.279976.431020 at cerise.gclements.plus.com>
>> To: Michael Barton <michael.barton at asu.edu>
>> Cc: grass-gui at grass.itc.it, GRASS devel <grass-dev at grass.itc.it>,
>> Daniel Calvelo <dca.gis at gmail.com>
>> Subject: Re: [GRASS-dev] d.rast.edit in wxgrass
>> In-Reply-To: <C296EEB3.2FDDB%michael.barton at asu.edu>
>> References: <18033.38623.341392.551825 at cerise.gclements.plus.com>
>> X-Mailer: VM 7.07 under 21.4 (patch 20) "Double Solitaire" XEmacs Lucid
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
