[GRASS-dev] Problems posting to grass-gui
Glynn Clements
glynn at gclements.plus.com
Fri Jun 15 13:25:10 EDT 2007
Any idea why my attempts to post to grass-gui keep bouncing?
> This is a MIME-encapsulated message
> --l5FGLYOc018107.1181924494/cerise.gclements.plus.com
> The original message was received at Fri, 15 Jun 2007 17:21:31 +0100
> from localhost [127.0.0.1]
> ----- The following addresses had permanent fatal errors -----
> <grass-gui at grass.itc.it>
> (reason: 550 5.1.1 <grass-gui at grass.itc.it>... User unknown)
> ----- Transcript of session follows -----
> ... while talking to grass.itc.it.:
> >>> DATA
> <<< 550 5.1.1 <grass-gui at grass.itc.it>... User unknown
> Content-Type: message/delivery-status
> Reporting-MTA: dns; cerise.gclements.plus.com
> Received-From-MTA: DNS; localhost
> Arrival-Date: Fri, 15 Jun 2007 17:21:31 +0100
> Final-Recipient: RFC822; grass-gui at grass.itc.it
> Action: failed
> Status: 5.1.1
> Remote-MTA: DNS; grass.itc.it
> Diagnostic-Code: SMTP; 550 5.1.1 <grass-gui at grass.itc.it>... User unknown
> Last-Attempt-Date: Fri, 15 Jun 2007 17:21:34 +0100
> Content-Type: message/rfc822
> Return-Path: <glynn at cerise.gclements.plus.com>
> Received: from cerise.gclements.plus.com (localhost [127.0.0.1])
> by cerise.gclements.plus.com (8.13.7/8.13.7) with ESMTP id l5FGLVOc018105;
> Received: (from glynn at localhost)
> by cerise.gclements.plus.com (8.14.0/8.14.0/Submit) id l5FGLVw7018102;
> From: Glynn Clements <glynn at gclements.plus.com>
> MIME-Version: 1.0
> Content-Type: text/plain; charset=us-ascii
> Content-Transfer-Encoding: 7bit
> Message-ID: <18034.48267.279976.431020 at cerise.gclements.plus.com>
> To: Michael Barton <michael.barton at asu.edu>
> Cc: grass-gui at grass.itc.it, GRASS devel <grass-dev at grass.itc.it>,
> Daniel Calvelo <dca.gis at gmail.com>
> Subject: Re: [GRASS-dev] d.rast.edit in wxgrass
> In-Reply-To: <C296EEB3.2FDDB%michael.barton at asu.edu>
> References: <18033.38623.341392.551825 at cerise.gclements.plus.com>
> X-Mailer: VM 7.07 under 21.4 (patch 20) "Double Solitaire" XEmacs Lucid
