[GRASS-dev] Re: Mac binary
Agustin Diez Castillo
Agustin.Diez at uv.es
Mon Jun 18 04:36:50 EDT 2007
After rebooting the mac machine, grass is working. Maybe the problem
was that I did ssh -Y to a linux box and this takes display ":0.0".
On Jun 16, 2007, at 1:33 AM, kyngchaos at kyngchaos.com wrote:
>> I got a tcltk error with both 6.3 cvs, my last compilation and your
>> 30 may installer. Same happens with 6.2
>> Application initialization failed: couldn't connect to display ":0.0"
>> Error in startup script: couldn't connect to display ":0.0"
>> while executing
>> "load /Applications/GRASS-6.3.app/Contents/Resources/lib/tk8.4/../
>> libtk8.4.dylib Tk"
>> ("package ifneeded" script)
>> invoked from within
>> "package require Tk 8.0"
>> invoked from within
>> "package require -exact BWidget 1.2.1"
>> (file "/Applications/GRASS-6.3.app/Contents/Resources/etc/dm/
>> d.m.tcl" line 23)
> I'm not sure. First, X11 needs to be running, of course. This
> should be
> taken of by the app startup.
> Do you have a DISPLAY setting in your .bash_profile? The app
> startup will
> set it to :0.0 for you, but only if it isn't set already. If you
> do have
> something in .bash_profile (or other shell init script), it may be set
> wrong. That's all I can think of.
> If it used to work, maybe you installed something that added a DISPLAY
> line to your .bash_profile?
> I don't use d.m, and only occassionally gis.m. gis.m works for me.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070618/ffdf978f/attachment.html
