[GRASS-dev] Re: Mac binary
kyngchaos at kyngchaos.com
Fri Jun 15 19:33:01 EDT 2007
> I got a tcltk error with both 6.3 cvs, my last compilation and your
> 30 may installer. Same happens with 6.2
> Application initialization failed: couldn't connect to display ":0.0"
> Error in startup script: couldn't connect to display ":0.0"
> while executing
> "load /Applications/GRASS-6.3.app/Contents/Resources/lib/tk8.4/../
> libtk8.4.dylib Tk"
> ("package ifneeded" script)
> invoked from within
> "package require Tk 8.0"
> invoked from within
> "package require -exact BWidget 1.2.1"
> (file "/Applications/GRASS-6.3.app/Contents/Resources/etc/dm/
> d.m.tcl" line 23)
I'm not sure. First, X11 needs to be running, of course. This should be
taken of by the app startup.
Do you have a DISPLAY setting in your .bash_profile? The app startup will
set it to :0.0 for you, but only if it isn't set already. If you do have
something in .bash_profile (or other shell init script), it may be set
wrong. That's all I can think of.
If it used to work, maybe you installed something that added a DISPLAY
line to your .bash_profile?
I don't use d.m, and only occassionally gis.m. gis.m works for me.
