[GRASS-dev] [grass-code R][428] Warn about wrong epsg code when creating a location in grass 6.2
grass-coder at wald.intevation.org grass-coder at wald.intevation.org
Sat Jun 16 17:39:01 EDT 2007
code R item #428, was opened at 2007-06-16 18:39
Status: Open
Priority: 3
Submitted By: Daniel Victoria (dvictori)
Assigned to: Nobody (None)
Summary: Warn about wrong epsg code when creating a location in grass 6.2
Issue status: None
GRASS component: startup
Operating system: None
Operating system version: Linux
Initial Comment:
When creating a location based on a georeferenced files, if the EPSG code is wrong there is no clear warning and no location gets created. This feature is already present in 6.3. Could it be backported?
Also, if a wrong EPSG code is input a tmp directory sometimes is created
thanks
Daniel
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=188&aid=428&group_id=21
