[GRASS-dev] Possible typos error in ./general/manage/cmd/rename.c:103
Sun Jun 17 20:11:03 EDT 2007
Hamish wrote:
> Carlos Dávila wrote:
> > I think there may be an error in ./general/manage/cmd/rename.c:103
> > (Renaming in reclassed map%s), but not sure the right form (¿map %s,
> G_message(_("Renaming in reclassed map%s"),
> 	  (nrmaps > 1 ? "s" : ""));
> if there is more than 1 map it adds an "s" to the end of the string.
> this sort of pluralization trick is probably not very transaltion safe,
> and should be avoided. Beyond that, I'm not really sure what that
> message is trying to say.
The "in" is a grammatical error; I've changed that line to:
	G_message(_("Renaming reclass maps"));
It's usually better to just always use the plural in such situations
than adding a special case for n == 1.
