[GRASS-dev] [grass-code I][431] g.copy segmentation fault
grass-codei at wald.intevation.org
Wed Jun 20 09:53:14 EDT 2007
code I item #431, was opened at 2007-06-20 13:53
Status: Open
Priority: 3
Submitted By: Otto Dassau (dassau)
Assigned to: Nobody (None)
Summary: g.copy segmentation fault
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: general
Operating system: Linux
Operating system version: debian testing
GRASS CVS checkout date, if applies (YYMMDD): 070620
Initial Comment:
the module g.copy segfaults.
example
g.copy rast=objekthoehen20,muell10
Copy raster <objekthoehen20 at testdaten> to current mapset as <muell10>
Speicherzugriffsfehler
with gdb I get following message (maybe helpful):
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1242368304 (LWP 12305)]
do_copy (n=0, old=0x80506b8 "objekthoehen20", mapset=0x8050800 "testdaten", new=0x80506d0 "muell") at do_copy.c:40
/data/software/grass6/general/manage/lib/do_copy.c:40:964:beg:0x8049abd
(gdb)
I have another CVS version running from 20070604 and it works there. And I start the segfaulting grass version from cvs directory (no make install). Could that be a problem?
thanks,
Otto
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=431&group_id=21
