[GRASS-dev] nviz compilation problem
Helena Mitasova
hmitaso at unity.ncsu.edu
Tue Jun 26 11:06:50 EDT 2007
I have compiled the CVS GRASS63 on a new 64bit computer with nvidia
graphics card running
RedHat Enterprise Linux. Everything compiled successfully except for
nviz that has some troubles with
shared GL libraries.
I have seen others with similar problems (I had it on another machine
too ) mostly due to broken symlink,
but that does not seem to be the case here:
Errors in:
/local/home/helena/grassdev/grass6/lib/ogsf
/local/home/helena/grassdev/grass6/visualization/nviz
(cd /local/home/helena/grassdev/grass6/dist.x86_64-unknown-linux-gnu/
lib; ln -f -s libgrass_ogsf.6.3.cvs.so /local/home/helena/grassdev/
grass6/dist.x86_64-unknown-linux-gnu/lib/libgrass_ogsf.so)
/usr/bin/ld: /usr/X11R6/lib64/libGL.a(glapi.o): relocation
R_X86_64_32 against `a local symbol' can not be used when making a
shared object; recompile with -fPIC
/usr/X11R6/lib64/libGL.a: could not read symbols: Bad value
collect2: ld returned 1 exit status
make: *** [/local/home/helena/grassdev/grass6/dist.x86_64-unknown-
linux-gnu/lib/libgrass_ogsf.6.3.cvs.so] Error 1
what to recompile with -fPIC? if that is really the problem?
thanks a lot for any hints,
Helena
