[GRASS-dev] grass classification routines and small / large
numbers
Markus Neteler
neteler at itc.it
Thu Jun 28 09:42:13 EDT 2007
Dylan Beaudette wrote on 06/26/2007 07:33 PM:
> Hi,
> I have found that using the GRASS classification modules work well when the
> inputs come from discreet (0-255) distributions- for example landsat
> channels, etc. - however I seem to get a lot of singularity problems, or maps
> with a single class when using floating point values of different magnitude.
Dylan, *,
there is i.pr available in the GRASS Addons repository from Stefano
Merler (my colleague from IRST):
https://grasssvn.itc.it/grasssvn/grassaddons/trunk/grassaddons/
* pr : C code for classification problems. It implements k-NN
(multiclass), classification trees (multiclass), maximum likelihood
(multiclass), Support Vector Machines (binary), bagging versions of all
the base classifiers, AdaBoost for binary trees and support vector
machines. It allows feature manipulation (normalization, principal
components,...). It also implements feature selection techniques (RFE,
E-RFE,...), statistical tests on variables, tools for resampling
(cross-validation and bootstrap) and cost-sensitive techniques for trees
and support vector machines. Feature selection techniques and
statistical tests are not distributed in the current release.
||| * i.pr : a version of pr implemented in the GIS GRASS for dealing
with images.
Maybe interesting?
Markus
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
