[GRASS-dev] Re: gis.m,
thematic layer: You must open a display monitor
Daniel Calvelo
dca.gis at gmail.com
Fri Mar 2 02:59:39 EST 2007
Sorry for the awful delay. I think the problems with d.mon select are
resolved; please test. I also made the legend cuts work for ps.map and
display managers. In CVS.
Daniel.
On 2/13/07, Daniel Calvelo <dca.gis at gmail.com> wrote:
> Hi Michael, Moritz.
> I'll look at it when I get home. That's in about 10 hours.
> Daniel.
> BTW did you try d.vect.thematic for >20 categories? Legends now do
> have their nice cut in the middle.
> On 2/13/07, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> > On 13/02/07 16:06, Michael Barton wrote:
> > > There should be a flag to send output to the gis manager. This flag should
> > > cause this conditional to be skipped.
> > The flag is $GIS_FLAG_S:
> > On line 860ff you have this:
> > # reset rendering for GUI use
> > if [ "$GIS_FLAG_S" -eq 1 ] ; then
> > d.mon select=$currmon
> > fi
> > In my understanding, unless someone works in parallel with GIS Manager
> > and x-mons, $currmon will be empty and this is where this error message
> > comes from.
> > Maybe it's just a problem of an unequal number of if and fi calls...
> > But I don't have the time to go into the file in detail now...sorry.
> > Moritz
> > > Michael
> > > On 2/13/07 7:58 AM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
> > >> On 13/02/07 15:29, Michael Barton wrote:
> > >>> I have no idea. Perhaps I'm imagining things, but I swear that I'm seeing a
> > >>> LOT more of these messages recently--with their deleterious effects on
> > >>> scripting. Hamish says they've been there all along. I'm suspecting that the
> > >>> code for the message has existed, but they did not get parsed for some
> > >>> reason. But that is just speculation.
> > >> Well in this case, there is a change by Daniel dated Jan. 28 which might
> > >> be linked:
> > >> - Added quotes in occurences of 'if [ -z "$var" ]'
> > >> But reverting back to no quotes gives the same error message.
> > >> Looking at the logic, I don't actually understand how this worked
> > >> before. As I said, IIUC the x-mon test seems to be done whether you are
> > >> using GIS Manager or not. But under GIS Manager there should be no x-mon...
> > >> Conditonalising the check as follows:
> > >> if [ "$GIS_FLAG_S" -eq 0 ] ; then
> > >> if [ -z "$currmon" ] ; then
> > >> echo ""
> > >> echo "*** You must open a display monitor ***"
> > >> echo ""
> > >> cleanup
> > >> exit 2
> > >> fi
> > >> fi
> > >> makes the error message go away, but I get a new one:
> > >> Usage: /usr/lib/grass/etc/mon.select monitor_name
> > >> This time, however, the map and legend are displayed correctly (without
> > >> the "fix" only the legend is displayed). I can get this second error
> > >> message to go away by commenting line 862:
> > >> # d.mon select=$currmon
> > >> This comes from the fact that $currmon is empty in GIS Manager. Again, I
> > >> don't understand why we have to deal with d.mon here if we are in the
> > >> GIS Manager...and why this did not cause any problems before.
> > >> Moritz
> > >>> Michael
> > >>> On 2/13/07 6:19 AM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
> > >>>> Michael,
> > >>>> I am seeing a new error for d.vect.thematic. Trying to display a
> > >>>> thematic layer fails with the message: *** You must open a display
> > >>>> monitor ***
> > >>>> I can reproduce this with any spearfish vector layer.
> > >>>> The problem seems to be in lines 336-345 where it checks for the
> > >>>> existance of an x-monitor. It seems to do this unconditionally, so even
> > >>>> if you run it from the GIS Manager it still checks and fails if there is
> > >>>> not monitor.
> > >>>> I can't find anything recent in the commit logs that would explain this,
> > >>>> so before trying to go deeper into it, I wanted to know if you had an
> > >>>> idea why this is suddenly happening.
> > >>>> Moritz
> > >>> __________________________________________
> > >>> Michael Barton, Professor of Anthropology
> > >>> School of Human Evolution & Social Change
> > >>> Center for Social Dynamics & Complexity
> > >>> Arizona State University
> > >>> phone: 480-965-6213
> > >>> fax: 480-965-7671
> > >>> www: http://www.public.asu.edu/~cmbarton
> > > phone: 480-965-6213
> > > fax: 480-965-7671
> -- Daniel Calvelo Aros
