[GRASS-dev] Re: gis.m,
thematic layer: You must open a display monitor
Moritz Lennert
mlennert at club.worldonline.be
Fri Mar 2 04:02:56 EST 2007
On 02/03/07 08:59, Daniel Calvelo wrote:
> Sorry for the awful delay. I think the problems with d.mon select are
> resolved; please test. I also made the legend cuts work for ps.map and
> display managers. In CVS.
I get the following error. The line
format [G_msg "Legend for Map %d, %s"] $mon, $opt($id,1,map)
seems to be the problem.
Moritz
expected integer but got "1,"
while executing
"format [G_msg "Legend for Map %d, %s"] $mon, $opt($id,1,map)"
(procedure "GmThematic::tlegend" line 11)
invoked from within
"GmThematic::tlegend $mon $id"
(procedure "GmThematic::display" line 72)
invoked from within
"GmThematic::display $node $mod"
("thematic" arm line 2)
invoked from within
"switch $type {
group {
GmGroup::display $node $mod
raster {
GmRaster::display $node $mod
labels {
GmLabels::disp..."
(procedure "GmTree::display_node" line 7)
invoked from within
"GmTree::display_node $n $mod"
(procedure "GmGroup::display" line 22)
invoked from within
"GmGroup::display "root" $mod"
(procedure "MapCanvas::runprograms" line 64)
invoked from within
"MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
(procedure "MapCanvas::drawmap" line 38)
invoked from within
"MapCanvas::drawmap $mon"
(procedure "MapCanvas::display_server" line 9)
invoked from within
("after" script)
> Daniel.
> On 2/13/07, Daniel Calvelo <dca.gis at gmail.com> wrote:
>> Hi Michael, Moritz.
>> I'll look at it when I get home. That's in about 10 hours.
>> Daniel.
>> BTW did you try d.vect.thematic for >20 categories? Legends now do
>> have their nice cut in the middle.
>> On 2/13/07, Moritz Lennert <mlennert at club.worldonline.be> wrote:
>> > On 13/02/07 16:06, Michael Barton wrote:
>> > > There should be a flag to send output to the gis manager. This
>> flag should
>> > > cause this conditional to be skipped.
>> > The flag is $GIS_FLAG_S:
>> > On line 860ff you have this:
>> > # reset rendering for GUI use
>> > if [ "$GIS_FLAG_S" -eq 1 ] ; then
>> > d.mon select=$currmon
>> > fi
>> > In my understanding, unless someone works in parallel with GIS Manager
>> > and x-mons, $currmon will be empty and this is where this error message
>> > comes from.
>> > Maybe it's just a problem of an unequal number of if and fi calls...
>> > But I don't have the time to go into the file in detail now...sorry.
>> > Moritz
>> > > Michael
>> > > On 2/13/07 7:58 AM, "Moritz Lennert"
>> > >> On 13/02/07 15:29, Michael Barton wrote:
>> > >>> I have no idea. Perhaps I'm imagining things, but I swear that
>> I'm seeing a
>> > >>> LOT more of these messages recently--with their deleterious
>> effects on
>> > >>> scripting. Hamish says they've been there all along. I'm
>> suspecting that the
>> > >>> code for the message has existed, but they did not get parsed
>> for some
>> > >>> reason. But that is just speculation.
>> > >> Well in this case, there is a change by Daniel dated Jan. 28
>> which might
>> > >> be linked:
>> > >> - Added quotes in occurences of 'if [ -z "$var" ]'
>> > >> But reverting back to no quotes gives the same error message.
>> > >> Looking at the logic, I don't actually understand how this worked
>> > >> before. As I said, IIUC the x-mon test seems to be done whether
>> you are
>> > >> using GIS Manager or not. But under GIS Manager there should be
>> no x-mon...
>> > >> Conditonalising the check as follows:
>> > >> if [ "$GIS_FLAG_S" -eq 0 ] ; then
>> > >> if [ -z "$currmon" ] ; then
>> > >> echo ""
>> > >> echo "*** You must open a display monitor ***"
>> > >> echo ""
>> > >> cleanup
>> > >> exit 2
>> > >> fi
>> > >> fi
>> > >> makes the error message go away, but I get a new one:
>> > >> Usage: /usr/lib/grass/etc/mon.select monitor_name
>> > >> This time, however, the map and legend are displayed correctly
>> (without
>> > >> the "fix" only the legend is displayed). I can get this second error
>> > >> message to go away by commenting line 862:
>> > >> # d.mon select=$currmon
>> > >> This comes from the fact that $currmon is empty in GIS Manager.
>> Again, I
>> > >> don't understand why we have to deal with d.mon here if we are in
>> the
>> > >> GIS Manager...and why this did not cause any problems before.
>> > >> Moritz
>> > >>> Michael
>> > >>> On 2/13/07 6:19 AM, "Moritz Lennert"
>> > >>>> Michael,
>> > >>>> I am seeing a new error for d.vect.thematic. Trying to display a
>> > >>>> thematic layer fails with the message: *** You must open a display
>> > >>>> monitor ***
>> > >>>> I can reproduce this with any spearfish vector layer.
>> > >>>> The problem seems to be in lines 336-345 where it checks for the
>> > >>>> existance of an x-monitor. It seems to do this unconditionally,
>> so even
>> > >>>> if you run it from the GIS Manager it still checks and fails if
>> there is
>> > >>>> not monitor.
>> > >>>> I can't find anything recent in the commit logs that would
>> explain this,
>> > >>>> so before trying to go deeper into it, I wanted to know if you
>> had an
>> > >>>> idea why this is suddenly happening.
>> > >>>> Moritz
>> > >>> __________________________________________
>> > >>> Michael Barton, Professor of Anthropology
>> > >>> School of Human Evolution & Social Change
>> > >>> Center for Social Dynamics & Complexity
>> > >>> Arizona State University
>> > >>> phone: 480-965-6213
>> > >>> fax: 480-965-7671
>> > >>> www: http://www.public.asu.edu/~cmbarton
>> > > phone: 480-965-6213
>> > > fax: 480-965-7671
>> -- Daniel Calvelo Aros
