[GRASS-dev] [bug #5263] (grass) r.to.vect: -v flag doesn't transfer cat values
Maciek Sieczka via RT grass-bugs at intevation.de
Sat Mar 3 05:09:00 EST 2007
this bug's URL: http://intevation.de/rt/webrt?serial_num=5263
Request number 5263 was commented on by 'msieczka' (Maciek Sieczka).
Responding to this message will send mail to the requestor.
			Request Tracker
			rt at intevation.de
Cc: hamish_nospam at yahoo.com,grass-dev at grass.itc.it
mlanda wrote (Wed, Feb 28 2007 16:57:04):
> Attributes for lines are not ignored (fixed in CVS today). But the problem
> with overlapping input raster cells of different value remains. Could be
> called as the feature?
Martin,
After you enabled attribute transfer for feature=line, it shows there is bug
there. Attributes are not transferred correctly from raster to vector lines.
In spearfish, do:
$ r.thin roads out=roads_thin
$ r.to.vect input=roads_thin output=roads_thin_vect feature=line
$ r.to.vect -v input=roads_thin output=roads_thin_vect_cat feature=line
Display them all and take a closer look at the horizontal roads located near
  599447(E) 4921873(N). Query the input raster roads_thin. As you can see the
values of lines on the left and right should be 5 and 4, respectively.
However, in roads_thin_vect there is only one line there, having value=4. In
roads_thin_vect_cat on the other hand, there are 2 lines with cat=5 on the
left and cat=4 on the right, but the line with cat=4 is about 740m too long.
Maybe that's why it was never enabled, ?.
Maciek
-------------------------------------------- Managed by Request Tracker
