[GRASS-dev] New feature (algorithm and / or module) to implent to GRASS (long)
Sun Mar 4 08:48:56 EST 2007
Wolf Bergenheim wrote:
> Is it OK if I create a branch[1] in CVS in the vector directory for
> this? That way you all can also observe my progress, and I will have the
> safety of version control during this process, and it won't mess the
> rest of the build system. Another option would be that I would simply
> work in the main trunk of the CVS, since my work will only be localized
> to the module I'm working on. What are your thoughts?
If all of your work will be in new files, just work on the trunk. A
branch is only justified if you intend to make significant,
incompatible changes to existing files.
